Introduzione
Use this guide to remove or replace your Samsung Galaxy Note II's battery.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Aggiungi Commento
Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
  • Lift the rear case by the corner nearest the divot and remove it from the phone.
Aggiungi Commento
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Aggiungi Commento
Remove the battery from the midframe.
  • Remove the battery from the midframe.
Aggiungi Commento
Conclusione
Altre 30 persone hanno completato questa guida.
Sam Lionheart
Membro da: 18/10/2012
323.874 Reputazione
1.664 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
6.002 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 82
Tutti i Tempi: 18,646
