Introduzione
Use this guide to install a new front-facing camera assembly in your Samsung Galaxy Note.
Grasp the cap of the stylus and remove it from its slot in the midframe. Grasp the cap of the stylus and remove it from its slot in the midframe.
  • Grasp the cap of the stylus and remove it from its slot in the midframe.
Aggiungi Commento
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker. Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Aggiungi Commento
Lift and remove the rear case from the phone. Lift and remove the rear case from the phone.
  • Lift and remove the rear case from the phone.
Aggiungi Commento
Insert your finger in the notch of the battery compartment. Press the battery toward the rear facing camera while pulling outward.
  • Insert your finger in the notch of the battery compartment.
  • Press the battery toward the rear facing camera while pulling outward.
Aggiungi Commento
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. For reassembly, push the microSD card into the slot until it clicks in place.
  • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
  • After the click, release the card and it will pop out of its slot.
  • For reassembly, push the microSD card into the slot until it clicks in place.
Aggiungi Commento
Remove the microSD card from its slot in the midframe.
  • Remove the microSD card from its slot in the midframe.
Aggiungi Commento
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment. Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Aggiungi Commento
Slide the SIM card out the rest of the way with your thumb and remove it from the device. Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
Aggiungi Commento
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Aggiungi Commento
Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry. Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
Aggiungi Commento
Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam.
  • Slide the plastic opening tool down the seam.
Aggiungi Commento
Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly. Slide the opening tool along the top edge of the phone. Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
  • Slide the opening tool along the top edge of the phone.
  • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
Aggiungi Commento
Remove the midframe from the display assembly. Remove the midframe from the display assembly.
  • Remove the midframe from the display assembly.
Aggiungi Commento
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
  • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
Aggiungi Commento
Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
Aggiungi Commento
Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket. Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
Aggiungi Commento
Using tweezers, or your fingers, remove the front-facing camera assembly. Using tweezers, or your fingers, remove the front-facing camera assembly.
  • Using tweezers, or your fingers, remove the front-facing camera assembly.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Sam Lionheart
Membro da: 18/10/2012
314.699 Reputazione
1.640 Guide realizzate
iFixit Membro di iFixit
Community
116 Membri
5.773 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,435
