Introduzione
The headphone jack is the port you connect your headphone to in order to receive the sound from the tablet through headphones. Over time, the headphone jack or the terminal connections can become worn out or damaged, which may result in headphones not receiving sound properly. In this case, the headphone jack has to be replaced and this guide will show you how.
Remove the Samsung S-Pen stylus.
  • Remove the Samsung S-Pen stylus.
  • Remove the micro SD storage card.
Aggiungi Commento
Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
Aggiungi Commento
Work your way around the entire device by carefully prying and sliding the plastic opening tool.
  • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
  • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
Aggiungi Commento
Remove the 8 Phillips#00 3-mm screws holding the battery in place. Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
The photo highlighting the screws is incorrect, the highlight in the upper right side is a plastic tab, whereas the actual 8th screw to remove is on the bottom (but that's fairly easy to identify when performing the fix).
fortyseveneffects - Replica
Lift the top left corner of the battery up by the black tab.
  • Lift the top left corner of the battery up by the black tab.
Aggiungi Commento
Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
  • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
  • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
the white battery connectory also has 2 black wires, so 2 blue/2red/2black
suziquirke - Replica
There is some sort of safe unit in the upper left corner. It is a connector that opens when you lift off the backside. The safe was not in properly fit when I closed the back. In fact, the most difficult step was to get the safe unit properly in place while closing the backside.
henriknaslund - Replica
Thanks @henriknaslund for note on the "Safe Unit" I succesfully managed to hold it in pace with a little basic sticky tape. Did the job.
derek - Replica
Piece of cake. Entire procedure took just 15 minutes. Thank you, Joel & Co., for making this so easy!
Flipped Gazelle - Replica
why is this under galaxy note 8? the note 8 is not a tablet??? Please respond to my comment as I will check back. I need to fix my NOTE 8 POWER BUTTON…does not work properly. Makes a “short” sound…as in electrical.
HELP!!
Barbara Lamb - Replica
The Galaxy Note 8 was the designation for the 8 inch WiFi tablet long before Samsung confused everyone with the Note 8 phone. When Im looking for items for the tablet I usually only get things for the phone.
J E De Armond - Replica
Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver. Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
  • Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
Aggiungi Commento
Gently pry up the teal connector. Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  • Gently pry up the teal connector.
  • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
Aggiungi Commento
Gently pry up the gold connector. Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  • Gently pry up the gold connector.
Aggiungi Commento
Remove the headphone jack from it's housing.
  • Remove the headphone jack from it's housing.
  • If difficult, use a plastic opening tool to pry up.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Joel
Membro da: 23/09/2014
1.681 Reputazione
12 Guide realizzate
USF Tampa, Team 12-2, Blackwell Fall 2014 Membro di USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Membri
16 Guide realizzate
Lightning struck while my son was on his tablet... no more headset audio? Replaced recommend parts still no audio. Plays fine without earbuds??? Insurance claim? What else could be the issue? Motherboard?
Shasta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 109
Tutti i Tempi: 4,493
