Introduzione
This guide will show you how to replace your SIM card in your Samsung Galaxy Note 4. You may need this guide if your phone is having trouble connecting to the cellular network.
Parti
Nessuna parte richiesta.
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera. Gently pry and twist the flexible rear cover off the back of the phone.
  • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
  • Gently pry and twist the flexible rear cover off the back of the phone.
Aggiungi Commento
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
  • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Aggiungi Commento
Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way. Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
Aggiungi Commento
Conclusione
Altre 27 persone hanno completato questa guida.
Derek Nola
Membro da: 06/01/2015
1.898 Reputazione
11 Guide realizzate
Cal Poly, Team 70-6, Forte Winter 2015 Membro di Cal Poly, Team 70-6, Forte Winter 2015
CPSU-FORTE-W15S70G6
4 Membri
15 Guide realizzate
Thanks too much
goooooogle319 - Replica
Many thanks my bro
Theres 5 pins next to sim card port. Can i ask..what is the purpose of that pin?
Nirza Dhom - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 132
Tutti i Tempi: 6,481
