Introduzione
This guide explains the way to replacing the headphone jack.
Insert the plastic opening tool or a fingernail in the gap between the rear case and the base of the phone.
  • Insert the plastic opening tool or a fingernail in the gap between the rear case and the base of the phone.
Aggiungi Commento
Slide the plastic opening tool along the edge of the rear case. Lift the case gently from the base.
  • Slide the plastic opening tool along the edge of the rear case.
  • Lift the case gently from the base.
Why... is it not simple enough already lol
Adam Ahmed - Replica
Insert the plastic opening tool into the small gap between the battery and the phone base. Lift the battery out of its placeholder.
  • Insert the plastic opening tool into the small gap between the battery and the phone base.
  • Lift the battery out of its placeholder.
Aggiungi Commento
Place your fingernail in the groove of the stylus pen.
  • Place your fingernail in the groove of the stylus pen.
  • Pull the stylus pen away from the phone.
Aggiungi Commento
Remove the twelve 4mm Phillips #00 screws from the back chassis.
  • Remove the twelve 4mm Phillips #00 screws from the back chassis.
Aggiungi Commento
Insert the plastic opening tool into the Stylus Pen placement holder.
  • Insert the plastic opening tool into the Stylus Pen placement holder.
  • Lift the plastic opening tool so that the midframe separates from the base.
Aggiungi Commento
Remove the single screw beside headphone jack. Remove the single screw beside headphone jack.
  • Remove the single screw beside headphone jack.
You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
Oriol Felisart - Replica
Use tweezers to remove both antenna clips. Use a spudger to disconnect six cable connectors.
  • Use tweezers to remove both antenna clips.
  • Use a spudger to disconnect six cable connectors.
Aggiungi Commento
Pull up on the motherboard with tweezers.
  • Pull up on the motherboard with tweezers.
Can i change at&t board to 9002 or 9005??,
Ayyaz - Replica
My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
soha Javed - Replica
My wifi hotspot is not working
Kiran Thopate - Replica
Insert the spudger into the headphone jack.
  • Insert the spudger into the headphone jack.
Aggiungi Commento
Lift the spudger to separate the jack assembly from the motherboard.
  • Lift the spudger to separate the jack assembly from the motherboard.
  • Pull to remove.
Aggiungi Commento
Conclusione
Altre 20 persone hanno completato questa guida.
Brittany Gail
Membro da: 23/09/2014
7.896 Reputazione
26 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2014 Membro di USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 151
Tutti i Tempi: 12,267
