This is the back of the device and where you willl begin to take it apart It is necessary to remove the silver piece covering the camera first before removing the bigger back piece. Use the plastic opening tools to pry along the indicated box.
  • This is the back of the device and where you willl begin to take it apart
  • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
  • Use the plastic opening tools to pry along the indicated box.
  • Lift up the silver piece to reveal the rest of the back cover.
Aggiungi Commento
Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver. Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top. Remove the back cover.
  • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
  • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
  • Remove the back cover.
  • At this point use anti-static gloves or do NOT take it apart on carpet.
Aggiungi Commento
Start by lifting the white connector to remove the part indicated by the red polygon. Gently pry along the camera hub to lift it out of its location. This is your camera.  Replace it with the new part.
  • Start by lifting the white connector to remove the part indicated by the red polygon.
  • Gently pry along the camera hub to lift it out of its location.
  • This is your camera. Replace it with the new part.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Bryan Fernandez
Membro da: 22/09/2014
232 Reputazione
2 Guide realizzate
USF Tampa, Team 3-7, Brown Fall 2014 Membro di USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,660
