Salta al contenuto principale
Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement
Cosa ti serve
  1. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: passo 1, immagine 1 di 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $2.99
    Compra
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: passo 2, immagine 1 di 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: passo 2, immagine 2 di 2
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
  3. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: passo 3, immagine 1 di 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: passo 3, immagine 2 di 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: passo 3, immagine 3 di 3
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
  4. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: passo 4, immagine 3 di 3
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
Conclusione
Altre 4 persone hanno completato questa guida.
Joseph Rasico
Membro da: 02/20/17
2.173 Reputazione
6 Guide realizzate
USF Tampa, Team S1-G6, Leahy Spring 2017 Membro di USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,626
