Introduzione
Are you not able to make any calls or send text messages?
Then, this guide will help you replace or insert a new Sim card onto your Galaxy Nexus.
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Aggiungi Commento
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Aggiungi Commento
Insert your finger into the divot of the  battery and pull the battery towards yourself to remove. This is when a new battery will be inserted. This is when a new battery will be inserted.
  • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
  • This is when a new battery will be inserted.
Aggiungi Commento
Using your fingers pull the Sim card out. This is a Verizon phone, however we are using a AT&T Sim card as an example as to where to put the sim card. This is a Verizon phone, however we are using a AT&T Sim card as an example as to where to put the sim card.
  • Using your fingers pull the Sim card out.
  • This is a Verizon phone, however we are using a AT&T Sim card as an example as to where to put the sim card.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Stephan Williams
Membro da: 22/09/2014
1.390 Reputazione
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,488
