Salta al contenuto principale
Samsung Galaxy Nexus Main Display Glass Replacement
Cosa ti serve
  1. Samsung Galaxy Nexus Main Display Glass Replacement, Removing Back Cover: passo 1, immagine 1 di 1
    • Open the back cover of the phone with your fingers or use the plastic opening tools to pry the back cover off of the phone.
    • Remove the battery by prying it free from the divot at the bottom.
    • Store the back cover and the battery in a safe place, such as a bowl, until you are ready to re-install them.
  2. Samsung Galaxy Nexus Main Display Glass Replacement: passo 2, immagine 1 di 1
    • Remove the four 4.5 mm Phillips screws from the rear of the phone.
  3. Samsung Galaxy Nexus Main Display Glass Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Nexus Main Display Glass Replacement: passo 3, immagine 2 di 2
    • Flip the phone over so that the screen faces upward.
    • Insert a plastic opening tool into the seam between the screen and the outer case. Work the plastic opening tool around the phone without removing it from the seam.
    • Slowly pry the outer case from the screen.
    • Work carefully. Excessive force can easily damage the case.
  4. Samsung Galaxy Nexus Main Display Glass Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Nexus Main Display Glass Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Nexus Main Display Glass Replacement: passo 4, immagine 3 di 3
    • Remove a single 4 mm Phillips #00 screw from the bottom of the phone.
    • Lift up the flat connector from its socket on the motherboard.
    • Lift the entire headphone jack assembly from the phone.
  5. Samsung Galaxy Nexus Main Display Glass Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Nexus Main Display Glass Replacement: passo 5, immagine 2 di 2
    • Disconnect the two ribbon cables from the motherboard.
  6. Samsung Galaxy Nexus Main Display Glass Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers or a spudger, lift the vibrator motor from its recess in the midframe.
  7. Samsung Galaxy Nexus Main Display Glass Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Nexus Main Display Glass Replacement: passo 7, immagine 2 di 2
    • Using tweezers, gently disconnect the antenna cable from its socket on the motherboard.
  8. Samsung Galaxy Nexus Main Display Glass Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Nexus Main Display Glass Replacement: passo 8, immagine 2 di 2
    • Use tweezers to pull the motherboard out of the phone.
    • Work carefully. Depending on the model, the underside of the motherboard may still have ribbon cables connecting it to the display assembly.
  9. Samsung Galaxy Nexus Main Display Glass Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Nexus Main Display Glass Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Nexus Main Display Glass Replacement: passo 9, immagine 3 di 3
    • Starting near the USB port, use your tweezers to pull the small daughterboard from the phone.
Conclusione
Altre 13 persone hanno completato questa guida.
2 Commenti
with this guide , I found this repair easy to do. Thank you Tom G.
Thomas Giles - Replica
Deberían d3 poner los diagramas eléctricos para reparar gracias
manchadoshow - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 20,686
