Begin by turn the device over to it's back, with the screen facing down.
  • Begin by turn the device over to it's back, with the screen facing down.
Aggiungi Commento
At the top of the device there is a small notch that is used to remove the battery door. Using a pry tool or your fingernail, pry off the battery door from the main housing.
  • At the top of the device there is a small notch that is used to remove the battery door.
  • Using a pry tool or your fingernail, pry off the battery door from the main housing.
Aggiungi Commento
Place the battery door to the side. Using a pry tool or your fingernail, pry the battery up towards you. You have now removed the battery!
  • Place the battery door to the side.
  • Using a pry tool or your fingernail, pry the battery up towards you.
  • You have now removed the battery!
Aggiungi Commento
Make sure when replacing the battery that the arrow on the bottom is facing down.
  • Make sure when replacing the battery that the arrow on the bottom is facing down.
Aggiungi Commento
Remove the 6 Phillips head screws that hold the rear housing in place.
  • Remove the 6 Phillips head screws that hold the rear housing in place.
Aggiungi Commento
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Aggiungi Commento
Lift the rear housing from the display assembly.
  • Lift the rear housing from the display assembly.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Josh Forester
Membro da: 28/11/2010
2.294 Reputazione
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 145
