Salta al contenuto principale
Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: passo 1, immagine 1 di 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: passo 1, immagine 2 di 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: passo 1, immagine 3 di 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: passo 2, immagine 1 di 2 Samsung Galaxy Alpha Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
Conclusione
Altre 10 persone hanno completato questa guida.
Jon Brausch
Membro da: 01/20/15
1.542 Reputazione
2 Guide realizzate
Cal Poly, Team 20-17, Maness Winter 2015 Membro di Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Membri
5 Guide realizzate
2 Commenti
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - Replica
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 39
Tutti i Tempi: 4,940
