Introduzione
Step-by-step guild to replacing your old worn out keyboard buttons.
Parti
Nessuna parte richiesta.
Press button on back of phone below camera.
  • Press button on back of phone below camera.
  • While button is depressed, remove the back panel of the phone by sliding off (not shown in picture).
Aggiungi Commento
Grasp the battery near the bottom with two fingers.
  • Grasp the battery near the bottom with two fingers.
  • Lift battery up and out gently.
Aggiungi Commento
Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
  • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
  • The upper right screw is 4.5mm while the rest are 6.5mm.
Aggiungi Commento
Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips. There are three clips on each side and two at the bottom of the phone.
  • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
  • There are three clips on each side and two at the bottom of the phone.
Aggiungi Commento
Once all eight of the clips have been unhooked, lift the back panel off of the phone.
  • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
  • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
Aggiungi Commento
Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
  • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
  • Carefully remove the ribbon.
Aggiungi Commento
Remove the front faceplate.
  • Remove the front faceplate.
Aggiungi Commento
Grasp the rubber keyboard in the corner with your fingers and lift to remove.
  • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
Aggiungi Commento
Conclusione
Chris
Membro da: 20/04/2011
27 Reputazione
1 Guida realizzata
Cal Poly, Team 15-15, Regan Spring 2011 Membro di Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,568
