Introduzione
Use this guide to replace the microSD card.
Parti
Nessuna parte richiesta.
Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack. Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
  • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
Aggiungi Commento
Lift and remove the rear case. Lift and remove the rear case.
  • Lift and remove the rear case.
Aggiungi Commento
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot.
  • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
  • After the click, release the card and it will pop out of its slot.
  • During reassembly, push the microSD card into the slot until it clicks in place.
Aggiungi Commento
Pull the microSD card away from its slot.
  • Pull the microSD card away from its slot.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Uhh.... my Australian SGSII looks different to this...
Bonj - Replica
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,092
