Introduzione
Use this guide to replace the rear-facing camera.
Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack. Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
  • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
Aggiungi Commento
Lift and remove the rear case. Lift and remove the rear case.
  • Lift and remove the rear case.
Aggiungi Commento
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot.
  • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
  • After the click, release the card and it will pop out of its slot.
  • During reassembly, push the microSD card into the slot until it clicks in place.
Aggiungi Commento
Pull the microSD card away from its slot.
  • Pull the microSD card away from its slot.
Aggiungi Commento
Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner. Push the plastic opening tool downward to pry the battery up from its housing.
  • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
  • Push the plastic opening tool downward to pry the battery up from its housing.
Aggiungi Commento
Lift and remove the battery from the midframe. Lift and remove the battery from the midframe.
  • Lift and remove the battery from the midframe.
Aggiungi Commento
Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
  • Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
Aggiungi Commento
Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them. The first insertion point is a divot to the left of the micro-USB port.
  • Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them.
    • The first insertion point is a divot to the left of the micro-USB port.
    • The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
    • The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
Aggiungi Commento
Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap. Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
  • Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
Aggiungi Commento
Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap. Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
  • Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
Aggiungi Commento
Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly. Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
  • Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
Aggiungi Commento
Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely. Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
  • Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
Aggiungi Commento
Headphone jack/vibrator assembly cable connector
  • Headphone jack/vibrator assembly cable connector
  • Front-facing camera cable connector
  • Digitizer cable connector
  • Display cable connector
Aggiungi Commento
Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable. Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
  • Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
Aggiungi Commento
Use the flat end of a spudger to disconnect the front-facing camera cable connector. Use the flat end of a spudger to disconnect the front-facing camera cable connector.
  • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
Aggiungi Commento
Carefully disconnect the digitizer display cable.
  • Carefully disconnect the digitizer display cable.
Aggiungi Commento
Use a spudger to disconnect the display cable connector.
  • Use a spudger to disconnect the display cable connector.
Aggiungi Commento
Remove the two 3 mm Phillips #00 screws.
  • Remove the two 3 mm Phillips #00 screws.
Aggiungi Commento
Lift the micro-USB end of the motherboard away from the display assembly and pull it down. Be mindful that you don't snag the motherboard on any cables as you remove it. Be mindful that you don't snag the motherboard on any cables as you remove it.
  • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
  • Be mindful that you don't snag the motherboard on any cables as you remove it.
Aggiungi Commento
The microphone cover fits in a notch and over a small peg in the display assembly, ensure it is well seated before sealing your device. Make sure the microphone cover stays in its slot on the display assembly.
  • The microphone cover fits in a notch and over a small peg in the display assembly, ensure it is well seated before sealing your device.
  • Make sure the microphone cover stays in its slot on the display assembly.
  • When you removed the motherboard, the microphone cover may have remained stuck on the microphone. Put it back in its notch in the display assembly to avoid losing it.
Aggiungi Commento
Use the pointed end of a spudger to flip the tab on the rear-facing camera ZIF connector. Use the pointed end of a spudger to flip the tab on the rear-facing camera ZIF connector.
  • Use the pointed end of a spudger to flip the tab on the rear-facing camera ZIF connector.
Aggiungi Commento
Slide a spudger under the rear-facing camera cable to free it from the adhesive. Slide a spudger under the rear-facing camera cable to free it from the adhesive.
  • Slide a spudger under the rear-facing camera cable to free it from the adhesive.
Aggiungi Commento
Remove the rear-facing camera from the motherboard.
  • Remove the rear-facing camera from the motherboard.
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
I replaced my camera twice, but when I try using the phone I get a message saying "camera failed", I put my old camera in and it works just fine. any advice?
carlos rodriguez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 10,237
