with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
Aggiungi Commento
locate the three (3) screws on the back panel of the device that are implanted in the device
  • locate the three (3) screws on the back panel of the device that are implanted in the device
  • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
Aggiungi Commento
to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
Aggiungi Commento
Conclusione
Devon Clements
Membro da: 21/10/2014
228 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Membro di UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 142
