Salta al contenuto principale
Samsung Chromebook Series 3 Motherboard Replacement
Cosa ti serve
  1. Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: passo 1, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: passo 1, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Motherboard Replacement: passo 3, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 3, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 3, immagine 3 di 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Motherboard Replacement: passo 4, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 4, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 4, immagine 3 di 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Motherboard Replacement, Battery: passo 5, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement, Battery: passo 5, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement, Battery: passo 5, immagine 3 di 3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Motherboard Replacement: passo 6, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 6, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 6, immagine 3 di 3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Chromebook Series 3 Motherboard Replacement: passo 7, immagine 2 di 2
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: passo 8, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: passo 8, immagine 3 di 3
    • Unscrew the four 3.1 mm screws holding the motherboard with a Phillips #00 screwdriver.
  9. Samsung Chromebook Series 3 Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 9, immagine 3 di 3
    • The audio cable can be removed by simply pulling gently.
    • Use the iFixit opening tool to pop out the 2 antennae lines from the motherboard.
  10. Samsung Chromebook Series 3 Motherboard Replacement: passo 10, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 10, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 10, immagine 3 di 3
    • Now, disconnect the keyboard and trackpad ribbon cables.
    • This requires lifting the lever securing the cables to free them, and then gently pulling them out.
  11. Samsung Chromebook Series 3 Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Chromebook Series 3 Motherboard Replacement: passo 11, immagine 3 di 3
    • The screen cable is secure in place by a lever. Lift the lever to release it, then gently pull it out.
  12. Samsung Chromebook Series 3 Motherboard Replacement: passo 12, immagine 1 di 1
    • This cable comes out by just pulling gently.
  13. Samsung Chromebook Series 3 Motherboard Replacement: passo 13, immagine 1 di 2 Samsung Chromebook Series 3 Motherboard Replacement: passo 13, immagine 2 di 2
    • Lift the motherboard out of place and pull out the CMOS battery cable.
  14. Samsung Chromebook Series 3 Motherboard Replacement: passo 14, immagine 1 di 2 Samsung Chromebook Series 3 Motherboard Replacement: passo 14, immagine 2 di 2
    • Finally, remove the three 3.1 mm screws with the Phillips #00 screwdriver to remove the plastic cover and completely free the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Tyler Schultz
Membro da: 03/25/19
528 Reputazione
3 Guide realizzate
IUPUI, Team S2-G1, Henning Spring 2019 Membro di IUPUI, Team S2-G1, Henning Spring 2019
IUPUI-HENNING-S19S2G1
3 Membri
6 Guide realizzate
2 Commenti
Please tell me what i can do to put a cmos back from scratch i understand how to wire and tape the cmos and i see where to connect it but i dont have the connector and am wondering if i solder negative where positive should go by accident am i goin to fry the mother board?
MrAaron Camethesameasalametame - Replica
Why is it so important also what is the meaning of it? Like are these contraptions built with almost enough power but always need a tiny bit more or whats the deal with a cmos?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,689
