Introduzione
This guide will help you change the battery in your Chromebook. It requires you to take the Chromebook apart, since the battery is located inside.
Lay the Chromebook down so that the bottom cover is facing up. Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive. Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  • Lay the Chromebook down so that the bottom cover is facing up.
  • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Aggiungi Commento
Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver. Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver. Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
Aggiungi Commento
Pry up the plastic strip on the back of the Chromebook using a plastic opening tool. It is not necessary to remove it completely. It just needs to be separated from the bottom cover. It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
  • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
Aggiungi Commento
Pry off the bottom cover using a plastic opening tool. Pry off the bottom cover using a plastic opening tool. Pry off the bottom cover using a plastic opening tool.
  • Pry off the bottom cover using a plastic opening tool.
Aggiungi Commento
Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver. Pull out the battery partway in order to easily get to the battery connector. Pull out the battery partway in order to easily get to the battery connector.
  • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
  • Pull out the battery partway in order to easily get to the battery connector.
Aggiungi Commento
Disconnect the battery connector by pulling straight up at its base. When reassembling, simply position the connector above it's original place, and push down. When reassembling, simply position the connector above it's original place, and push down.
  • Disconnect the battery connector by pulling straight up at its base.
  • When reassembling, simply position the connector above it's original place, and push down.
Aggiungi Commento
You can now remove the battery. You can now remove the battery.
  • You can now remove the battery.
Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Andrey Radchishin
Membro da: 21/01/2015
1.128 Reputazione
4 Guide realizzate
UWT Liner: Group 1 Membro di UWT Liner: Group 1
Community
5 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 114
Tutti i Tempi: 2,389
