Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K05US Battery Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K05US Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 3, immagine 2 di 2
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 4, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 4, immagine 2 di 2
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 5, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 5, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 6, immagine 1 di 1
    • Lift the battery out of the case to remove it from the laptop.
Conclusione
Gateway, Team 4-4, Gonzalez Spring 2023 Membro di Gateway, Team 4-4, Gonzalez Spring 2023
GCC-GONZALEZ-S23S4G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 147
