Salta al contenuto principale
Samsung Chromebook 2 Screen Replacement
Cosa ti serve
  1. Samsung Chromebook 2 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
  2. Samsung Chromebook 2 Screen Replacement: passo 2, immagine 1 di 3 Samsung Chromebook 2 Screen Replacement: passo 2, immagine 2 di 3 Samsung Chromebook 2 Screen Replacement: passo 2, immagine 3 di 3
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
  3. Samsung Chromebook 2 Screen Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 3, immagine 2 di 2
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
  4. Samsung Chromebook 2 Screen Replacement: passo 4, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 4, immagine 2 di 2
    • Once the cover is loose, remove the back cover panel using your hands.
  5. Samsung Chromebook 2 Screen Replacement: passo 5, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 5, immagine 2 di 2
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
  6. Samsung Chromebook 2 Screen Replacement: passo 6, immagine 1 di 3 Samsung Chromebook 2 Screen Replacement: passo 6, immagine 2 di 3 Samsung Chromebook 2 Screen Replacement: passo 6, immagine 3 di 3
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
  7. Samsung Chromebook 2 Screen Replacement, Screen: passo 7, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement, Screen: passo 7, immagine 2 di 2
    • Replace the back cover by clicking it into place with your hands.
    • No need to replace the screws, this is just to protect the internal hardware while working on the screen.
  8. Samsung Chromebook 2 Screen Replacement: passo 8, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 8, immagine 2 di 2
    • Open the laptop and place it so that the back of the screen is laying on a flat surface.
    • Insert a plastic opening tool between the front cover and plastic screen trim.
    • Work the plastic opening tool all around the trim.
    • Don't be afraid to use your hands to pull the trim from the front panel.
  9. Samsung Chromebook 2 Screen Replacement: passo 9, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 9, immagine 2 di 2
    • Flip the computer over so that the keys and screen are facing down.
    • Insert the spudger between the back and front panel, at the hinge, and push the trim out.
  10. Samsung Chromebook 2 Screen Replacement: passo 10, immagine 1 di 1
    • Place the laptop in a position where it is resting on the back of the screen.
    • Remove the trim from the front panel by pulling up with your hands.
  11. Samsung Chromebook 2 Screen Replacement: passo 11, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 11, immagine 2 di 2
    • Using a Phillips #0 screwdriver to unscrew the four 3 mm screws keeping the screen in place.
  12. Samsung Chromebook 2 Screen Replacement: passo 12, immagine 1 di 2 Samsung Chromebook 2 Screen Replacement: passo 12, immagine 2 di 2
    • Using the spudger, pry the screen loose from the front panel.
    • Do not try to remove the screen yet, it is still connect by a wire.
  13. Samsung Chromebook 2 Screen Replacement: passo 13, immagine 1 di 3 Samsung Chromebook 2 Screen Replacement: passo 13, immagine 2 di 3 Samsung Chromebook 2 Screen Replacement: passo 13, immagine 3 di 3
    • Place the laptop in an upright position.
    • When you place the Chromebook in this position the screen may fall off, so make sure to hold onto it.
    • Pull back the screen to locate the LCD cable, and disconnect it by pulling the black tape that surrounds it towards you.
  14. Samsung Chromebook 2 Screen Replacement: passo 14, immagine 1 di 1
    • Pull the screen from the front panel using your hands to fully remove it.
Conclusione
Altre 10 persone hanno completato questa guida.
UW Tacoma, Team 1-3, Rose Winter 2016 Membro di UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 7,175
