Introduzione
Motherboard malfunctions can cause a multitude of issues to transpire like disabling your phone to turn on even when properly charged, The device vibrates and turns on, but the screen remains blank, And or the device keeps turning on and off on its own.
Although difficult but if done carefully, these steps allow you to access, replace, and resolve your seeking issue with Samsung Captivate's Motherboard.
Cosa ti serve
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
Lift up the black NEC chip with attached ribbon cable using either a spudger or plastic opening tool.
Gently lift the camera assembly out of the plastic housing.
Using the spudger slide the tool under the three highlighted connectors to begin disconnection
Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
Altre 14 persone hanno completato questa guida.
Un commento
hi, I have the captivate and I cannot get it to charge, i have had the charging port connection repaired in the past, but now I cannot get it to charge again
