Introduzione
How to remove the motherboard of a Samsung Captivate Glide.
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Aggiungi Commento
Remove battery with plastic opening tool or finger. Remove battery with plastic opening tool or finger.
  • Remove battery with plastic opening tool or finger.
Aggiungi Commento
Remove the seven screws from backplate using the #00 screwdriver. Remove the seven screws from backplate using the #00 screwdriver.
  • Remove the seven screws from backplate using the #00 screwdriver.
Aggiungi Commento
Remove the back plate using the plastic opening tool. There is a lip on each side, and both must be pried up. You can work your way around the edges after prying the two sides.
  • Remove the back plate using the plastic opening tool.
  • There is a lip on each side, and both must be pried up.
  • You can work your way around the edges after prying the two sides.
Aggiungi Commento
Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone. Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
Aggiungi Commento
Disconnect the antenna cable from the motherboard using tweezers.
  • Disconnect the antenna cable from the motherboard using tweezers.
Aggiungi Commento
Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
Aggiungi Commento
Lift the motherboard out of the base of the phone. Lift the motherboard out of the base of the phone.
  • Lift the motherboard out of the base of the phone.
Aggiungi Commento
Conclusione
Nicholas Mira
Membro da: 23/09/2014
280 Reputazione
2 Guide realizzate
USF Tampa, Team 5-3, Mcgee Fall 2014 Membro di USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 501
