Introduzione
Sometimes the earpiece can become damaged or loose and needs to be replaced. Follow this guide to fix this problem.
Remove the back cover by pressing on  the bottom section of the phone and sliding the bottom piece downward.
  • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
  • Lift up the back cover.
Aggiungi Commento
Place your finger on the bottom of the battery and lift to remove.
  • Place your finger on the bottom of the battery and lift to remove.
Aggiungi Commento
Replace the old battery with the new one.
  • Replace the old battery with the new one.
Aggiungi Commento
Insert the spudger underneath the bottom section of the phone.
  • Insert the spudger underneath the bottom section of the phone.
  • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Aggiungi Commento
Remove the six 4.5mm #000 Phillips screws.
  • Remove the six 4.5mm #000 Phillips screws.
Aggiungi Commento
Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
  • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
  • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
Aggiungi Commento
Separate the rear case from the phone.
  • Separate the rear case from the phone.
Aggiungi Commento
Use a spudger tool to pry up the antenna cable from the connector on the motherboard. Pry up the other end of the cable from the connector on the antenna array.
  • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
  • Pry up the other end of the cable from the connector on the antenna array.
Aggiungi Commento
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
Aggiungi Commento
Gently lift the camera assembly out of the plastic housing.
  • Gently lift the camera assembly out of the plastic housing.
Aggiungi Commento
Use a spudger to disconnect the three highlighted connectors. Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself. Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
  • Use a spudger to disconnect the three highlighted connectors.
  • Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
Aggiungi Commento
Use your fingers to lift up the logic board from the assembly.
  • Use your fingers to lift up the logic board from the assembly.
Aggiungi Commento
Gently pull up on the audio jack, taking the attached ribbon cable with it. There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
  • Gently pull up on the audio jack, taking the attached ribbon cable with it.
  • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
Be careful when reassembling rear cover as there are 2 tabs at the top of the case that can easily bend and eventually crack of giving no support to the top closure.
AB Computer Services - Replica
The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
  • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Drew Bentz
Membro da: 22/09/2011
565 Reputazione
5 Guide realizzate
Cal Poly, Team 20-25, Maness Fall 2011 Membro di Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,110
