Introduzione
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
Parti
Nessuna parte richiesta.
Remove the back cover by pressing on  the bottom section of the phone and sliding the bottom piece downward.
  • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
  • Lift up the back cover.
Aggiungi Commento
Place your finger on the bottom of the battery and lift to remove.
  • Place your finger on the bottom of the battery and lift to remove.
Aggiungi Commento
Replace the old battery with the new one.
  • Replace the old battery with the new one.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Insert the spudger underneath the bottom section of the phone.
  • Insert the spudger underneath the bottom section of the phone.
  • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Aggiungi Commento
Remove the six 4.5mm #000 Phillips screws.
  • Remove the six 4.5mm #000 Phillips screws.
Aggiungi Commento
Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
  • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
  • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
Aggiungi Commento
Separate the rear case from the phone.
  • Separate the rear case from the phone.
Aggiungi Commento
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
Aggiungi Commento
Gently lift the camera assembly out of the plastic housing.
  • Gently lift the camera assembly out of the plastic housing.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Drew Bentz
Membro da: 22/09/2011
565 Reputazione
5 Guide realizzate
Cal Poly, Team 20-25, Maness Fall 2011 Membro di Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Membri
9 Guide realizzate
Is this for the front facing camera
tracy mann - Replica
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,985
