Salta al contenuto principale
Samsung CLP-300 Imaging Unit Replacement
  1. Samsung CLP-300 Imaging Unit Replacement, Imaging Unit: passo 1, immagine 1 di 1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Imaging Unit Replacement: passo 2, immagine 1 di 2 Samsung CLP-300 Imaging Unit Replacement: passo 2, immagine 2 di 2
    • Open the front cover
  3. Samsung CLP-300 Imaging Unit Replacement: passo 3, immagine 1 di 1
    • Remove waste toner container from the printer.
  4. Samsung CLP-300 Imaging Unit Replacement: passo 4, immagine 1 di 3 Samsung CLP-300 Imaging Unit Replacement: passo 4, immagine 2 di 3 Samsung CLP-300 Imaging Unit Replacement: passo 4, immagine 3 di 3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
    • Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
    • Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 13,168
