Remove the battery cover by pushing it upwards. Remove the battery cover by pushing it upwards.
  • Remove the battery cover by pushing it upwards.
Aggiungi Commento
Pull out the battery.
  • Pull out the battery.
Aggiungi Commento
With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
  • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
  • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
Aggiungi Commento
Pull off the back cover of the phone.
  • Pull off the back cover of the phone.
Aggiungi Commento
Remove the volume and camera buttons.
  • Remove the volume and camera buttons.
Aggiungi Commento
Put the buttons aside until it is time to reassemble the phone.
  • Put the buttons aside until it is time to reassemble the phone.
Aggiungi Commento
Use a small plastic prying tool to remove the motherboard from the rest of the phone.
  • Use a small plastic prying tool to remove the motherboard from the rest of the phone.
Aggiungi Commento
Gently grab the motherboard with tweezers, then disconnect it from the two attached plates. Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
  • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
Aggiungi Commento
Snap the new motherboard back into place.
  • Snap the new motherboard back into place.
Aggiungi Commento
Reverse the steps to reassemble. Reverse the steps to reassemble.
  • Reverse the steps to reassemble.
Aggiungi Commento
Conclusione
Paige Weinstein
Membro da: 11/02/2014
1 Reputazione
2 Guide realizzate
Ohio State, Team 1-5, Buehl Spring 2014 Membro di Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 202
