Your phone should look like this before disassembly. Your phone should look like this before disassembly.
  • Your phone should look like this before disassembly.
Aggiungi Commento
Remove the battery cover by sliding the back panel up. This will expose the battery. Remove the battery cover by sliding the back panel up. This will expose the battery.
  • Remove the battery cover by sliding the back panel up. This will expose the battery.
Aggiungi Commento
Lift up the top portion of the battery and pull it out.
  • Lift up the top portion of the battery and pull it out.
  • Next, slide the sim card out of its socket and set it aside.
Aggiungi Commento
Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case. The top two screws are connected to the back cover. They will not come off once unscrewed.
  • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
  • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
Aggiungi Commento
Remove the buttons for the camera and volume. Remove the buttons for the camera and volume.
  • Remove the buttons for the camera and volume.
Aggiungi Commento
Use a prying tool to detach the motherboard from main body. Carefully detach the motherboard from the two connectors. You could also use a pry tool for the second step.
  • Use a prying tool to detach the motherboard from main body.
  • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
Aggiungi Commento
Slide the keyboard straight up to free it from its alignment pins. Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
  • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Aggiungi Commento
Conclusione
Jordan Taylor
Membro da: 11/02/2014
1 Reputazione
2 Guide realizzate
Ohio State, Team 1-5, Buehl Spring 2014 Membro di Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 191
