Salta al contenuto principale
Samsung Blackjack Speaker Replacement
Cosa ti serve
  1. Samsung Blackjack Speaker Replacement, Battery Cover: passo 1, immagine 1 di 3 Samsung Blackjack Speaker Replacement, Battery Cover: passo 1, immagine 2 di 3 Samsung Blackjack Speaker Replacement, Battery Cover: passo 1, immagine 3 di 3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Speaker Replacement, Battery: passo 2, immagine 1 di 2 Samsung Blackjack Speaker Replacement, Battery: passo 2, immagine 2 di 2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Speaker Replacement, SIM Card: passo 3, immagine 1 di 3 Samsung Blackjack Speaker Replacement, SIM Card: passo 3, immagine 2 di 3 Samsung Blackjack Speaker Replacement, SIM Card: passo 3, immagine 3 di 3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Speaker Replacement, Back Phone Casing: passo 4, immagine 1 di 2 Samsung Blackjack Speaker Replacement, Back Phone Casing: passo 4, immagine 2 di 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Speaker Replacement: passo 5, immagine 1 di 3 Samsung Blackjack Speaker Replacement: passo 5, immagine 2 di 3 Samsung Blackjack Speaker Replacement: passo 5, immagine 3 di 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Speaker Replacement, Motherboard: passo 6, immagine 1 di 2 Samsung Blackjack Speaker Replacement, Motherboard: passo 6, immagine 2 di 2
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  7. Samsung Blackjack Speaker Replacement: passo 7, immagine 1 di 2 Samsung Blackjack Speaker Replacement: passo 7, immagine 2 di 2
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  8. Samsung Blackjack Speaker Replacement: passo 8, immagine 1 di 2 Samsung Blackjack Speaker Replacement: passo 8, immagine 2 di 2
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
  9. Samsung Blackjack Speaker Replacement, Speaker: passo 9, immagine 1 di 2 Samsung Blackjack Speaker Replacement, Speaker: passo 9, immagine 2 di 2
    • Use the spudger to wedge between the speaker and the speaker's casing.
    • Use the spudger to pry on the speaker until it comes free from the casing.
Conclusione
Kristin Manna
Membro da: 10/22/12
29 Reputazione
10 Guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 398
