Introduzione
Use this guide to replace a broken screen.
Hold the device with the screen facing away from you and the camera towards you. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  • Hold the device with the screen facing away from you and the camera towards you.
  • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Aggiungi Commento
Place your fingers on both sides of the bottom of the battery and lift upwards. Pull the battery away from the phone.
  • Place your fingers on both sides of the bottom of the battery and lift upwards.
  • Pull the battery away from the phone.
Aggiungi Commento
Place your thumb on the SIM card. Slide the card out of the slot. Slide the card out of the slot.
  • Place your thumb on the SIM card.
  • Slide the card out of the slot.
Aggiungi Commento
Use the spudger to remove the rubber stoppers from the top of the cover. Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  • Use the spudger to remove the rubber stoppers from the top of the cover.
  • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Aggiungi Commento
Use the spudger to loosen and separate the front and back covers. Pick up the back cover once loosened. The front and back covers will be attached to each other by a gold wire.
  • Use the spudger to loosen and separate the front and back covers.
  • Pick up the back cover once loosened.
  • The front and back covers will be attached to each other by a gold wire.
  • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Aggiungi Commento
Use the screwdriver to unscrew the four screws that hold the scroll wheel in place. Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
  • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
Aggiungi Commento
Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board. Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
  • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
  • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
Aggiungi Commento
Use the spudger to unsnap the black rectangular connection from the motherboard. Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  • Use the spudger to unsnap the black rectangular connection from the motherboard.
  • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
Aggiungi Commento
Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing. Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
Aggiungi Commento
Once all of the connections have been snapped off of the motherboard, the motherboard can be removed. Lift up on the motherboard and it will come free of the front casing.
  • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
  • Lift up on the motherboard and it will come free of the front casing.
Aggiungi Commento
Use the spudger to break the glue that bonds the screen to the logic board. Remove the screen from the logic board. The screen will still be connected by a gold ribbon connection. While gently lifting upwards on the green part of the logic board, slide the gold ribbon connected that is to the screen through the space in the side of the logic board.
  • Use the spudger to break the glue that bonds the screen to the logic board.
  • Remove the screen from the logic board. The screen will still be connected by a gold ribbon connection.
  • While gently lifting upwards on the green part of the logic board, slide the gold ribbon connected that is to the screen through the space in the side of the logic board.
Aggiungi Commento
Conclusione
Everett
Membro da: 22/10/2012
13 Reputazione
2 Guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 374
