Introduzione
Use this guide to replace a broken or damaged antenna.
Hold the device with the screen facing away from you and the camera towards you. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  • Hold the device with the screen facing away from you and the camera towards you.
  • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Aggiungi Commento
Place your fingers on both sides of the bottom of the battery and lift upwards. Pull the battery away from the phone.
  • Place your fingers on both sides of the bottom of the battery and lift upwards.
  • Pull the battery away from the phone.
Aggiungi Commento
Place your thumb on the SIM card. Slide the card out of the slot. Slide the card out of the slot.
  • Place your thumb on the SIM card.
  • Slide the card out of the slot.
Aggiungi Commento
Use the spudger to remove the rubber stoppers from the top of the cover. Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  • Use the spudger to remove the rubber stoppers from the top of the cover.
  • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Aggiungi Commento
Use the spudger to loosen and separate the front and back covers. Pick up the back cover once loosened. The front and back covers will be attached to each other by a gold wire.
  • Use the spudger to loosen and separate the front and back covers.
  • Pick up the back cover once loosened.
  • The front and back covers will be attached to each other by a gold wire.
  • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Aggiungi Commento
Note: The antenna is located on the back case of the phone.  Flip over the back case of the phone so that the interior is facing up. Use spudger to help loosen the antenna.
  • Note: The antenna is located on the back case of the phone. Flip over the back case of the phone so that the interior is facing up.
  • Use spudger to help loosen the antenna.
  • Once the antenna is loose, use tweezers to remove antenna.
Aggiungi Commento
Use the Phillips 00 screwdriver to remove the screw from the casing around the speaker. Use tweezers to lift the casing around the speaker. Use spudger to dislodge the speaker.
  • Use the Phillips 00 screwdriver to remove the screw from the casing around the speaker.
  • Use tweezers to lift the casing around the speaker.
  • Use spudger to dislodge the speaker.
Aggiungi Commento
Conclusione
Kristin Manna
Membro da: 22/10/2012
17 Reputazione
10 Guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 342
