Introduzione
Use this guide to install, remove, or replace the battery. This guide is useful for the Troubleshooting Page.
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone. Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Aggiungi Commento
Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone. Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
Aggiungi Commento
Conclusione
Ryan Rumsey
Membro da: 30/01/2013
8 Reputazione
6 Guide realizzate
Cal Poly, Team 20-1, Maness Winter 2013 Membro di Cal Poly, Team 20-1, Maness Winter 2013
CPSU-MANESS-W13S20G1
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 203
