push down the back cover of the phone, then take it out.
  • push down the back cover of the phone, then take it out.
Aggiungi Commento
Remove the battery.
  • Remove the battery.
Aggiungi Commento
Remove the two (4.1 mm) screws down the screen.
  • Remove the two (4.1 mm) screws down the screen.
Aggiungi Commento
Remove the upper casing with a plastic opening tools. Remove the upper casing with a plastic opening tools.
  • Remove the upper casing with a plastic opening tools.
Aggiungi Commento
Use soldering iron to melt, and remove soldering joints of the speaker.
  • Use soldering iron to melt, and remove soldering joints of the speaker.
Aggiungi Commento
Use tweezers to remove the speaker from its place. Note: There are two speakers. Make sure you know which one is broken before removing it.
  • Use tweezers to remove the speaker from its place.
  • Note: There are two speakers. Make sure you know which one is broken before removing it.
Aggiungi Commento
Use tweezers to insert the new speaker into the speaker slot. Use tweezers to insert the new speaker into the speaker slot.
  • Use tweezers to insert the new speaker into the speaker slot.
Aggiungi Commento
Solder a speaker ribbon to the logic board.
  • Solder a speaker ribbon to the logic board.
  • Note: be careful to match the right polarity before you solder.
Aggiungi Commento
Conclusione
Chris
Membro da: 16/04/2011
133 Reputazione
10 Guide realizzate
Cal Poly, Team 12-35, Maness Spring 2011 Membro di Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,936
