Salta al contenuto principale
Samsung Admire Motherboard Replacement
Cosa ti serve
  1. Samsung Admire Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • To open the back cover of the phone, use your fingernail or plastic opening tool under the slit to pull the cover up.
  2. Samsung Admire Motherboard Replacement, Remove Battery: passo 2, immagine 1 di 1
    • Carefully remove the battery by placing your fingernail underneath the hole and pull out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Motherboard Replacement, Remove the screws: passo 3, immagine 1 di 3 Samsung Admire Motherboard Replacement, Remove the screws: passo 3, immagine 2 di 3 Samsung Admire Motherboard Replacement, Remove the screws: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Be careful not to lose the screws, so place them on a magnetic mat.
  4. Samsung Admire Motherboard Replacement, Inside back cover: passo 4, immagine 1 di 3 Samsung Admire Motherboard Replacement, Inside back cover: passo 4, immagine 2 di 3 Samsung Admire Motherboard Replacement, Inside back cover: passo 4, immagine 3 di 3
    • Use the Plastic Opening tools to remove the inside back cover.
    • Place the Plastic Opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Motherboard Replacement, Motherboard: passo 5, immagine 1 di 3 Samsung Admire Motherboard Replacement, Motherboard: passo 5, immagine 2 di 3 Samsung Admire Motherboard Replacement, Motherboard: passo 5, immagine 3 di 3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button away from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
    • Remove the motherboard completely from the phone
Conclusione
Altre 9 persone hanno completato questa guida.
Thao Uyen Do
Membro da: 01/20/15
896 Reputazione
4 Guide realizzate
USF Tampa, Team 7-5, Remmell Winter 2015 Membro di USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,305
