Introduzione
If the main display on your phone is cracked, depicting a frozen image, or not displaying an image at all, then installing a new display may fix these problems.
Parti
Nessuna parte richiesta.
To remove the back casing, firmly press down and push towards the bottom of the phone. To remove the back casing, firmly press down and push towards the bottom of the phone. To remove the back casing, firmly press down and push towards the bottom of the phone.
  • To remove the back casing, firmly press down and push towards the bottom of the phone.
Aggiungi Commento
With the casing removed, lift the battery from the indicated indentation.
  • With the casing removed, lift the battery from the indicated indentation.
Aggiungi Commento
From here, you can now access the SIM card and model/serial numbers.
  • From here, you can now access the SIM card and model/serial numbers.
Aggiungi Commento
Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
Aggiungi Commento
Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone. Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
  • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
Aggiungi Commento
To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
Aggiungi Commento
Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released. The power, volume, and camera buttons may fall out when separating the front and back casing.
  • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
  • The power, volume, and camera buttons may fall out when separating the front and back casing.
Aggiungi Commento
Your casing should be separated and the three loose buttons put to the side.
  • Your casing should be separated and the three loose buttons put to the side.
  • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
Aggiungi Commento
Slowly remove the back casing by gently pulling the ribbon connection. Slowly remove the back casing by gently pulling the ribbon connection.
  • Slowly remove the back casing by gently pulling the ribbon connection.
Aggiungi Commento
Gently pull on the wires to remove the front casing. Gently pull on the wires to remove the front casing.
  • Gently pull on the wires to remove the front casing.
Aggiungi Commento
Your front casing and front speaker are now released.
  • Your front casing and front speaker are now released.
Aggiungi Commento
Locate the display screen. Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
  • Locate the display screen.
  • Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
  • It may help to insert the pointed edge of the spudger into the small indentation shown on the right in the second image.
Aggiungi Commento
Slide the spudger across the bottom of the display and slowly push up. Slide the spudger across the bottom of the display and slowly push up. Slide the spudger across the bottom of the display and slowly push up.
  • Slide the spudger across the bottom of the display and slowly push up.
Aggiungi Commento
Slowly pry the spudger up to remove the display.
  • Slowly pry the spudger up to remove the display.
Aggiungi Commento
To remove the casing as a whole, slowly lift up and towards the right side of the phone.
  • To remove the casing as a whole, slowly lift up and towards the right side of the phone.
  • Be aware of the wiring on the right side of the phone connecting the display.
Aggiungi Commento
Conclusione
Breanne
Membro da: 12/04/2012
187 Reputazione
5 Guide realizzate
Cal Poly, Team 6-24, Amido Spring 2012 Membro di Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,322
