Introduzione
If your current case is damaged, this guide will help you install a new case to protect your phone from further abuse.
Parti
Nessuna parte richiesta.
To remove the back casing, firmly press down and push towards the bottom of the phone. To remove the back casing, firmly press down and push towards the bottom of the phone. To remove the back casing, firmly press down and push towards the bottom of the phone.
  • To remove the back casing, firmly press down and push towards the bottom of the phone.
Aggiungi Commento
With the casing removed, lift the battery from the indicated indentation.
  • With the casing removed, lift the battery from the indicated indentation.
Aggiungi Commento
From here, you can now access the SIM card and model/serial numbers.
  • From here, you can now access the SIM card and model/serial numbers.
Aggiungi Commento
Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
Aggiungi Commento
Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone. Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
  • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
Aggiungi Commento
To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
Aggiungi Commento
Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released. The power, volume, and camera buttons may fall out when separating the front and back casing.
  • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
  • The power, volume, and camera buttons may fall out when separating the front and back casing.
Aggiungi Commento
Your casing should be separated and the three loose buttons put to the side.
  • Your casing should be separated and the three loose buttons put to the side.
  • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
Aggiungi Commento
Slowly remove the back casing by gently pulling the ribbon connection. Slowly remove the back casing by gently pulling the ribbon connection.
  • Slowly remove the back casing by gently pulling the ribbon connection.
Aggiungi Commento
Gently pull on the wires to remove the front casing. Gently pull on the wires to remove the front casing.
  • Gently pull on the wires to remove the front casing.
Aggiungi Commento
Your front casing and front speaker are now released.
  • Your front casing and front speaker are now released.
Aggiungi Commento
Conclusione
Breanne
Membro da: 12/04/2012
187 Reputazione
5 Guide realizzate
Cal Poly, Team 6-24, Amido Spring 2012 Membro di Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 722
