Introduzione
This guide will be showing step-by-step instructions on how to get to and replace the safety of the airsoft gun.
Using a flathead screwdriver, remove the pin holding the hand guard in place. To remove this, turn the pin clockwise and push it through at the same time.
  • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
  • Remove the hand guard.
Aggiungi Commento
Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
Aggiungi Commento
Turn the gun over so that you are facing the bottom of the gun. Using a Phillips #1 screwdriver, remove the following screws:
  • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
Aggiungi Commento
Carefully tug on the tip of the gun and pull the barrel and its cover out. Carefully tug on the tip of the gun and pull the barrel and its cover out.
  • Carefully tug on the tip of the gun and pull the barrel and its cover out.
Aggiungi Commento
Locate the hand grip. Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip. Slide the cover off.
  • Locate the hand grip.
  • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
  • Slide the cover off.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Pull the motor out of the hand grip. Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
  • Pull the motor out of the hand grip.
  • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
Aggiungi Commento
Locate the pin holding the folding stock in place. Using an allen wrench or something small, carefully push the pin out.
  • Locate the pin holding the folding stock in place.
  • Using an allen wrench or something small, carefully push the pin out.
Aggiungi Commento
Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox. Remove the cover that was held on by the screw.
  • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
  • Remove the cover that was held on by the screw.
Aggiungi Commento
Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun. Slide off the piece that was held on by those screws. Slide off the piece that was held on by those screws.
  • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
  • Slide off the piece that was held on by those screws.
Aggiungi Commento
Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun. The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
  • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
Aggiungi Commento
Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun. Carefully remove the pieces that were held on by the screws.
  • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
  • Carefully remove the pieces that were held on by the screws.
Aggiungi Commento
Pull apart the cover when pulling the gearbox out. Pull the gearbox out. The gears will fall out when taking the gearbox out. Careful not to lose them.
  • Pull apart the cover when pulling the gearbox out.
  • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
Aggiungi Commento
Using a Phillips #0 screwdriver, remove the single 3mm screw holding the safety/trigger cover in place.
  • Using a Phillips #0 screwdriver, remove the single 3mm screw holding the safety/trigger cover in place.
Aggiungi Commento
Remove the cover over the trigger. The safety is located underneath the cover.
  • Remove the cover over the trigger.
    • The safety is located underneath the cover.
Aggiungi Commento
Conclusione
Anika Morris
Membro da: 05/10/2012
1 Reputazione
4 Guide realizzate
Cal Poly, Team 18-41, Regan Fall 2012 Membro di Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 469
