Salta al contenuto principale
Rival Mini Chopper MC-67BL Turning Gears Replacement
Cosa ti serve
  1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: passo 1, immagine 1 di 2 Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: passo 1, immagine 2 di 2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 2, immagine 1 di 1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 3, immagine 1 di 1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 4, immagine 1 di 1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 5, immagine 1 di 2 Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 5, immagine 2 di 2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 6, immagine 1 di 1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 7, immagine 1 di 1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 8, immagine 1 di 3 Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 8, immagine 2 di 3 Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 8, immagine 3 di 3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
Conclusione
Roxanne
Membro da: 10/17/13
522 Reputazione
4 Guide realizzate
Cal Poly, Team 4-29, Amido Fall 2013 Membro di Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 805
