Introduzione
This guide will help you remove the safety latch for the container lid.
Twist the plastic lid counterclockwise to unlock it. Lift the lid to remove it from the container.
  • Twist the plastic lid counterclockwise to unlock it.
  • Lift the lid to remove it from the container.
Aggiungi Commento
Carefully remove the blade from the container.
  • Carefully remove the blade from the container.
  • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
Aggiungi Commento
With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Aggiungi Commento
Use your fingers to pry out the two rubber feet from the bottom cover of the base.
  • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
  • The two feet furthest from the button tower contain screws. The other two feet do not.
Aggiungi Commento
Use the Phillips #2 screwdriver  to unscrew the two 12.7-mm screws underneath the rubber feet. Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
  • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Aggiungi Commento
Firmly lift the bottom cover off of the base.
  • Firmly lift the bottom cover off of the base.
Aggiungi Commento
Remove the smaller white gear by lifting it up with your hand.
  • Remove the smaller white gear by lifting it up with your hand.
Aggiungi Commento
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base. Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin. Continue turning the gear until completely removed from the blade-shaft.
  • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
  • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
  • Continue turning the gear until completely removed from the blade-shaft.
Aggiungi Commento
Use your hand to firmly pull the blade-shaft from the base.
  • Use your hand to firmly pull the blade-shaft from the base.
Aggiungi Commento
Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
Aggiungi Commento
Unwind power cord from the base pegs.
  • Unwind power cord from the base pegs.
Aggiungi Commento
Use the plastic opening tool to pry open the base from the main body. These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
  • Use the plastic opening tool to pry open the base from the main body.
  • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
  • Once freed, lift the base panel from the main body and set it aside.
Aggiungi Commento
Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body. Next, turn the device upright and lift the upper casing from around the button gently.
  • Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
  • Next, turn the device upright and lift the upper casing from around the button gently.
Aggiungi Commento
Remove the button by simply pulling it up.
  • Remove the button by simply pulling it up.
  • Don't lose the spring under the button! Without it, the blender will not function.
Aggiungi Commento
Use the Phillips #2 screwdriver to remove one 9.53-mm screw.
  • Use the Phillips #2 screwdriver to remove one 9.53-mm screw.
Aggiungi Commento
Remove the white latch by unhooking it from the spring wire and gently lifting straight up.
  • Remove the white latch by unhooking it from the spring wire and gently lifting straight up.
Aggiungi Commento
Conclusione
Roxanne
Membro da: 17/10/2013
507 Reputazione
4 Guide realizzate
Cal Poly, Team 4-29, Amido Fall 2013 Membro di Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,180
