Salta al contenuto principale
Rival 16131 Toaster Power Wire Repair
Cosa ti serve
  1. Rival 16131 Toaster Power Wire Repair, Shell: passo 1, immagine 1 di 2 Rival 16131 Toaster Power Wire Repair, Shell: passo 1, immagine 2 di 2
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
  2. Rival 16131 Toaster Power Wire Repair: passo 2, immagine 1 di 2 Rival 16131 Toaster Power Wire Repair: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
  3. Rival 16131 Toaster Power Wire Repair: passo 3, immagine 1 di 3 Rival 16131 Toaster Power Wire Repair: passo 3, immagine 2 di 3 Rival 16131 Toaster Power Wire Repair: passo 3, immagine 3 di 3
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
  4. Rival 16131 Toaster Power Wire Repair: passo 4, immagine 1 di 1
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
  5. Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: passo 5, immagine 1 di 2 Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: passo 5, immagine 2 di 2
    • The power wire connects to the toaster in the area highlighted.
    • To free the wire, unscrew the two .5 inch screws, and remove the white brace.
  6. Rival 16131 Toaster Power Wire Repair: passo 6, immagine 1 di 1
    • To solder the the wire, the circuit board has to be released.
    • To do this, unscrew the .5 inch screw located in the middle of the board.
    • Slowly lift the board up off the toaster, making sure that the red pegs that hold the board in place do not break.
  7. Rival 16131 Toaster Power Wire Repair: passo 7, immagine 1 di 1
    • To reattach the wire, follow this solder guide.
    • Solder Guide
Conclusione
Grant Haug
Membro da: 09/26/12
148 Reputazione
4 Guide realizzate
Cal Poly, Team 2-8, Propen Fall 2012 Membro di Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,927
