Salta al contenuto principale
Ring Video Doorbell Battery Replacement
Cosa ti serve
  1. Ring Video Doorbell Battery Replacement, Battery: passo 1, immagine 1 di 3 Ring Video Doorbell Battery Replacement, Battery: passo 1, immagine 2 di 3 Ring Video Doorbell Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: passo 2, immagine 1 di 3 Ring Video Doorbell Battery Replacement: passo 2, immagine 2 di 3 Ring Video Doorbell Battery Replacement: passo 2, immagine 3 di 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
Conclusione
Altre 2 persone hanno completato questa guida.
Abdulrahman
Membro da: 02/20/18
685 Reputazione
3 Guide realizzate
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro di USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Membri
10 Guide realizzate
4 Commenti
Where do I get a replacement battery?
William Price - Replica
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Replica
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Replica
can it be sent to the manufacturers for a replacement
d.rayyan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 366
Tutti i Tempi: 8,887
