Introduzione
This guide will take you through the process required to reset your Netgear router.
Parti
Nessuna parte richiesta.
Rotate device so the back panel is facing you.
  • Rotate device so the back panel is facing you.
  • Locate the reset button. It is located on the metal grating next to the antenna.
Aggiungi Commento
Push the reset button using a tool, along the lines of a pencil or paper clip, until you hear the button click. The router has now reverted to original user name and password settings
  • Push the reset button using a tool, along the lines of a pencil or paper clip, until you hear the button click.
  • The router has now reverted to original user name and password settings
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Ryan Murphy
Membro da: 03/10/2011
482 Reputazione
5 Guide realizzate
Cal Poly, Team 21-24, Maness Fall 2011 Membro di Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,872
