Salta al contenuto principale
Replacing the Macintosh PowerBook 1400c Monitor
Cosa ti serve
  1. Replacing the Macintosh PowerBook 1400c Monitor, Battery: passo 1, immagine 1 di 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Replacing the Macintosh PowerBook 1400c Monitor: passo 2, immagine 1 di 1
    • Slide the latch to the left to release the battery.
  3. Replacing the Macintosh PowerBook 1400c Monitor: passo 3, immagine 1 di 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Replacing the Macintosh PowerBook 1400c Monitor, CD-ROM Drive: passo 4, immagine 1 di 1
    • Locate the CD-ROM Drive latch.
  5. Replacing the Macintosh PowerBook 1400c Monitor: passo 5, immagine 1 di 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Replacing the Macintosh PowerBook 1400c Monitor: passo 6, immagine 1 di 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Replacing the Macintosh PowerBook 1400c Monitor, Keyboard: passo 7, immagine 1 di 1
    • Locate the speaker cover.
  8. Replacing the Macintosh PowerBook 1400c Monitor: passo 8, immagine 1 di 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Replacing the Macintosh PowerBook 1400c Monitor: passo 9, immagine 1 di 1
    • Gently lift the speaker cover to remove it.
  10. Replacing the Macintosh PowerBook 1400c Monitor: passo 10, immagine 1 di 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Replacing the Macintosh PowerBook 1400c Monitor: passo 11, immagine 1 di 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Replacing the Macintosh PowerBook 1400c Monitor: passo 12, immagine 1 di 1
    • Tilt the keyboard away from the screen.
  13. Replacing the Macintosh PowerBook 1400c Monitor: passo 13, immagine 1 di 1
    • Locate the six screws that secure the heatsink.
  14. Replacing the Macintosh PowerBook 1400c Monitor: passo 14, immagine 1 di 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Replacing the Macintosh PowerBook 1400c Monitor: passo 15, immagine 1 di 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Replacing the Macintosh PowerBook 1400c Monitor: passo 16, immagine 1 di 1
    • Remove the heatsink.
  17. Replacing the Macintosh PowerBook 1400c Monitor: passo 17, immagine 1 di 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Replacing the Macintosh PowerBook 1400c Monitor: passo 18, immagine 1 di 1
    • Detach the ribbon cable.
  19. Replacing the Macintosh PowerBook 1400c Monitor: passo 19, immagine 1 di 1
    • Remove the keyboard.
  20. Replacing the Macintosh PowerBook 1400c Monitor, Monitor: passo 20, immagine 1 di 1
    • Identify the right and left monitor end caps.
  21. Replacing the Macintosh PowerBook 1400c Monitor: passo 21, immagine 1 di 1
    • Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
  22. Replacing the Macintosh PowerBook 1400c Monitor: passo 22, immagine 1 di 1
    • Once the end cap has been loosened by the spudger, pull outwards on the end caps.
  23. Replacing the Macintosh PowerBook 1400c Monitor: passo 23, immagine 1 di 1
    • Completely remove both end caps.
  24. Replacing the Macintosh PowerBook 1400c Monitor: passo 24, immagine 1 di 1
    • Identify the 4 total screw under the end caps (2 under each end cap).
    • The two outside 16mm long screws
    • The two inside 5.4mm long screws
  25. Replacing the Macintosh PowerBook 1400c Monitor: passo 25, immagine 1 di 1
    • Lay the monitor all the way back.
  26. Replacing the Macintosh PowerBook 1400c Monitor: passo 26, immagine 1 di 1
    • Remove the 4 screws using the Phillips #0 screwdriver.
  27. Replacing the Macintosh PowerBook 1400c Monitor: passo 27, immagine 1 di 1
    • Identify the center cap of the monitor.
  28. Replacing the Macintosh PowerBook 1400c Monitor: passo 28, immagine 1 di 1
    • Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
  29. Replacing the Macintosh PowerBook 1400c Monitor: passo 29, immagine 1 di 1
    • Detach the center cap completely.
  30. Replacing the Macintosh PowerBook 1400c Monitor: passo 30, immagine 1 di 1
    • Identify the one 12.6mm long screw under the center cap.
  31. Replacing the Macintosh PowerBook 1400c Monitor: passo 31, immagine 1 di 1
    • Remove the center screw with a Phillips #0 screwdriver.
  32. Replacing the Macintosh PowerBook 1400c Monitor: passo 32, immagine 1 di 1
    • Lift upwards on the metal cover under the screw.
  33. Replacing the Macintosh PowerBook 1400c Monitor: passo 33, immagine 1 di 1
    • Completely remove the metal cover.
  34. Replacing the Macintosh PowerBook 1400c Monitor: passo 34, immagine 1 di 1
    • Identify where the left and right monitor cords are attached to the logic board
    • The base of the left monitor cord
    • The base of the right monitor cord
  35. Replacing the Macintosh PowerBook 1400c Monitor: passo 35, immagine 1 di 1
    • To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
  36. Replacing the Macintosh PowerBook 1400c Monitor: passo 36, immagine 1 di 1
    • Completely detach the left monitor cord from the logic board.
  37. Replacing the Macintosh PowerBook 1400c Monitor: passo 37, immagine 1 di 1
    • To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
  38. Replacing the Macintosh PowerBook 1400c Monitor: passo 38, immagine 1 di 1
    • Completely detach the right monitor cord from the logic board.
  39. Replacing the Macintosh PowerBook 1400c Monitor: passo 39, immagine 1 di 1
    • Completely remove the monitor from the computer.
Conclusione
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
Altre 5 persone hanno completato questa guida.
Taylor Chris
Membro da: 04/01/11
187 Reputazione
1 Guida realizzata
Cal Poly, Team 10-39, Forte Spring 2011 Membro di Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,173
