Introduzione
The circuit board is the component of the phone that allows communication between all of the inputs and outputs within the phone in order to perform tasks that the user requires.
Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
  • Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
  • Remove the back battery cover by sliding it downward and pushing simultaneously.
  • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
Aggiungi Commento
Using either your thumb or the opening tools, remove the battery by prying you in the direction of the arrow
  • Using either your thumb or the opening tools, remove the battery by prying you in the direction of the arrow
  • If removing battery is for the replacement of a new battery make sure to properly dispose of the old battery at a recycling center.
Aggiungi Commento
Remove the rubber inserts from the screw holes using the black metal tweezers.  This is done by insering the tip of the metal tweezer down around the plastic insert. Remove the rubber inserts from the screw holes using the black metal tweezers.  This is done by insering the tip of the metal tweezer down around the plastic insert.
  • Remove the rubber inserts from the screw holes using the black metal tweezers. This is done by insering the tip of the metal tweezer down around the plastic insert.
Aggiungi Commento
Remove the 3.1mm long, Phillips #00 screws (Qty: 4)  from the corners. This is done by turning the skrew driver counter clockwise using little torque. This is done by turning the skrew driver counter clockwise using little torque.
  • Remove the 3.1mm long, Phillips #00 screws (Qty: 4) from the corners.
  • This is done by turning the skrew driver counter clockwise using little torque.
Aggiungi Commento
Seperate the phone's front case from the back case. There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well. There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
  • Seperate the phone's front case from the back case.
  • There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
Aggiungi Commento
Remove volume slider button by using the tweezers to pry it out.
  • Remove volume slider button by using the tweezers to pry it out.
  • The volume slider button may fall out during the seperation of the front and back cases, this is ok.
Aggiungi Commento
Use the opening tools to seperate the circuit board from inside of the back case by prying between the circuit board and the case as shown. The last picture is a view of the back of the circuit board. The last picture is a view of the back of the circuit board.
  • Use the opening tools to seperate the circuit board from inside of the back case by prying between the circuit board and the case as shown.
  • The last picture is a view of the back of the circuit board.
Aggiungi Commento
Conclusione
John Bender
Membro da: 26/03/2014
822 Reputazione
16 Guide realizzate
Clemson, Team 6-5, Benson Spring 2014 Membro di Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 127
