Introduzione
This is an easy guide to replacing the rear buttons on the Sanyo VPC-X1200.
Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
  • Remove the five case screws with a Phillips #00 Screwdriver.
  • Five 3.5mm Phillips Screws
Aggiungi Commento
Gently lift up the back cover and set aside.
  • Gently lift up the back cover and set aside.
Aggiungi Commento
Use small plastic pry tool to gently remove rear button plate.
  • Use small plastic pry tool to gently remove rear button plate.
  • A heat gun may be used to soften the glue for easier removal.
Aggiungi Commento
Conclusione
Cal Poly, Team 7-10, Maness Spring 2010 Membro di Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,325
