Introduzione
Step-by-step guide to replacing your phone's logic board.
Parti
Nessuna parte richiesta.
Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
  • Flip phone to see back cover.
  • Using either finger or spugder tool press button located near the top of phone by the antenna.
Aggiungi Commento
Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
  • Pry up back plate from phone to reveal battery.
  • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
Aggiungi Commento
Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
Aggiungi Commento
Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
  • Simultaneously press indicated buttons on both sides of phone.
Aggiungi Commento
Separate back plate from the rest of phone.
  • Separate back plate from the rest of phone.
  • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
Aggiungi Commento
Gently lift logic board from back plate.
  • Gently lift logic board from back plate.
Aggiungi Commento
Place logic board on front cover. Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  • Place logic board on front cover.
  • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Aggiungi Commento
Conclusione
Elizabeth OBrien
Membro da: 26/04/2010
31 Reputazione
14 Guide realizzate
Cal Poly, Team 30-40, Garner Spring 2010 Membro di Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Membri
14 Guide realizzate
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,909
