Introduzione
How to remove the keyboard cover.
Remove the 7 mm Philip screws.
  • Remove the 7 mm Philip screws.
  • Remove the 10 mm Philip screws.
  • Remove the 14 mm Philip screw.
Aggiungi Commento
Open the flap on the left hand side. Open the flap on the left hand side.
  • Open the flap on the left hand side.
Aggiungi Commento
Insert the iPod opening tools between the right and left sides of the latch. Pry the right side  of the latch, and then pry the left side to detach the laptop's cover.
  • Insert the iPod opening tools between the right and left sides of the latch.
  • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
Aggiungi Commento
Open the flap on the right side. Open the flap on the right side.
  • Open the flap on the right side.
Aggiungi Commento
Insert the iPod opening tools towards the right side of the latch.
  • Insert the iPod opening tools towards the right side of the latch.
  • Gently pry the right side out to release the top cover.
Aggiungi Commento
Lift the keyboard slowly. A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  • Lift the keyboard slowly.
  • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
Aggiungi Commento
Use your fingers or a spudger to detach the connector.
  • Use your fingers or a spudger to detach the connector.
Aggiungi Commento
Carefully lift and remove the keyboard. Carefully lift and remove the keyboard.
  • Carefully lift and remove the keyboard.
Aggiungi Commento
Conclusione
Derek Driscoll
Membro da: 15/04/2010
110 Reputazione
16 Guide realizzate
Cal Poly, Team 26-27, Regan Spring 2010 Membro di Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,457
