Introduzione
The speaker is an output component that plays sound.
Using a spudger, wedge the tip between the front and back case to pry them apart. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  • Using a spudger, wedge the tip between the front and back case to pry them apart.
  • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
Aggiungi Commento
The black rubber button pad can be removed by simply picking it up.
  • The black rubber button pad can be removed by simply picking it up.
Aggiungi Commento
Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
Aggiungi Commento
Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
  • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
  • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
Aggiungi Commento
Lift open the LCD screen and button input chip to access the entire midsection plate.
  • Lift open the LCD screen and button input chip to access the entire midsection plate.
Aggiungi Commento
Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
Aggiungi Commento
Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
Aggiungi Commento
Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case. Once unscrewed, pick up the case and put it to the side.
  • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
  • Once unscrewed, pick up the case and put it to the side.
Aggiungi Commento
With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
  • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
Aggiungi Commento
Conclusione
Westley Courchene
Membro da: 13/01/2015
2.578 Reputazione
14 Guide realizzate
USF Tampa, Team 1-1, Remmell Fall 2015 Membro di USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 108
