Salta al contenuto principale
Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines
Cosa ti serve
  1. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines, Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 1, immagine 1 di 1
    • Do your printed papers have these or similar vertical black and yellow lines?
    • Then this is the tutorial for you to make them disappear
  2. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 2, immagine 1 di 2 Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 2, immagine 2 di 2
    • Open the printer front and take everything out
    • Take out the toners
    • Take out the drum together with the waste bin
  3. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 3, immagine 1 di 1
    • Your printer should now look like in the image attached
    • Use a flashlight to see inside the printer
    • On the glossy black plastic you will see vertical lines of color which are the cause of your printers problem
  4. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 4, immagine 1 di 3 Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 4, immagine 2 di 3 Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 4, immagine 3 di 3
    • Use a small white paper and try to stick it into the top - like shown
    • Move it from left to right and drag it out again
    • You will see that it is pretty dirty afterwards
    • Do this multiple times and clean the black glossy plastic with a cotton cloth - be careful not to scratch it
  5. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: passo 5, immagine 1 di 1
    • Close the printer again and print some pages
    • After the 2nd or 3rd the black vertical lines should be gone completely
    • Have fun - again!
Conclusione
Altre 12 persone hanno completato questa guida.
7 Commenti
Michael I have a thick horizontal line that repeats as a Ghost image. Will this help fix it? I have tried cleaning the paper track and the rollers etc, with no such luck.
garthnathaniel - Replica
same here, if i print a blank page it has various horizontal shadows and looks dirty
Kevin Voyson - Replica
My printer was many years practically only B&W because of awful colors. This trick helped to restore colors. Thank you!
visitor visitor - Replica
Step 4: you can also clean the bottom (and not only the top) of the black glossy plastic: it was the root cause of my black lines
Tested with CLX-3185FW
Thanks
Jean-Baptiste Beaufreton - Replica
this will laso work for the samsunc clp-310(n,w) and the clp-315(n,w)
thijs kunst - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 56
Tutti i Tempi: 41,801
