Before disassembly, make sure that the device is unplugged.
  • Before disassembly, make sure that the device is unplugged.
  • Unscrew the two 17.83 mm black screws located on the handle.
Aggiungi Commento
Separate the shell from the main component.
  • Separate the shell from the main component.
  • Make sure that the each piece is free from debris.
Aggiungi Commento
Continue to pull the components apart. For reassembly, put the silver encasing on before the the black cover. For reassembly, put the silver encasing on before the the black cover.
  • Continue to pull the components apart.
  • For reassembly, put the silver encasing on before the the black cover.
Aggiungi Commento
Locate the switches in the handle of the device.
  • Locate the switches in the handle of the device.
Aggiungi Commento
Set the multimeter to 200 ACV.
  • Set the multimeter to 200 ACV.
Aggiungi Commento
Bring the probes toward each switch to test for continuity.
  • Bring the probes toward each switch to test for continuity.
  • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
  • If the meter stays at a finite number, the circuit is open and the switch needs to be replaced.
  • To replace faulty switch, cut the wires and solder the wires back on to the new switch.
Aggiungi Commento
Conclusione
Jessica Leyva
Membro da: 18/09/2012
80 Reputazione
5 Guide realizzate
Cal Poly, Team 1-5, Propen Fall 2012 Membro di Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 788
