Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Introduzione
The Quasar MQ7774XW microwave was introduced in 1984. This replacement repair guide shows the necessary steps that must be taken if sparking occurs on the inside of the microwave.
Parti
Disconnect the power supply cord from the outlet.
  • Disconnect the power supply cord from the outlet.
Aggiungi Commento
Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
  • Remove the eight screws holding the wood-patterned cover to the microwave frame.
  • The first four screws are located on either side of the microwave front.
Aggiungi Commento
Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
  • Remove the additional four screws securing the wood-paneled case to the microwave frame.
Aggiungi Commento
Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
  • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
  • Lift the case upward slowly until the case is free of the microwave.
Aggiungi Commento
First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
  • First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
  • If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
Aggiungi Commento
If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
  • If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
  • A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
Aggiungi Commento
Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
  • Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
  • Fixing the magnetron without the aid of a qualified professional is NOT recommended. The magnetron is an emitter of microwave radiation and tampering with it may lead to serious injury or death.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Michael
Membro da: 26/09/2012
183 Reputazione
2 Guide realizzate
Cal Poly, Team 2-12, Propen Fall 2012 Membro di Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,859
