Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Parti
Nessuna parte richiesta.
Disconnect the power supply cord from the outlet.
  • Disconnect the power supply cord from the outlet.
Aggiungi Commento
Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
  • Remove the eight screws holding the wood-patterned cover to the microwave frame.
  • The first four screws are located on either side of the microwave front.
Aggiungi Commento
Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
  • Remove the additional four screws securing the wood-paneled case to the microwave frame.
Aggiungi Commento
Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
  • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
  • Lift the case upward slowly until the case is free of the microwave.
Aggiungi Commento
Locate the fan in the newly exposed interior. Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
  • Locate the fan in the newly exposed interior.
  • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
  • If the fan does not spin freely, locate what is jamming the fan and remove it.
Aggiungi Commento
If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
  • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
  • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Aggiungi Commento
Conclusione
Melanie
Membro da: 26/09/2012
59 Reputazione
2 Guide realizzate
Cal Poly, Team 2-12, Propen Fall 2012 Membro di Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,061
